stay in open loop
kptuck
Stroker Displacement: 4.9L
stay in open loop
Post by kptuck »
To address my current issues, I am considering taking the steps to keep my 2000 TJ in open loop at all times.
Does anyone know what steps I have to take to do this? :huh:
Basically my engine runs and shifts great when cold, and then falls flat at 4200 RPM when it warms up.
I have a topic on the Stroker Basics forum if you want to read the details of my dilemna.
Kevin, 2000 TJ - "Casper"
4.9L stroker, Dynatrac Pro Rock 60's, 40" MTR's, 5.38 gears with ARB carriers, Kilby Air, Premier Welder, Walker Evans Bead Locks, Rubicon Express 8" Long Arm, AGR Steering...
kptuck
Re: stay in open loop
Post by kptuck »
bump :stick:
anyone know if by disconnecting the coolant temp sensor if the PCM will stay in open loop?
It appears it does, but you would need a piggy back tuner to make that work. However you will have a check engine light on. I had put some thought into this and I think if you put a resistor in that gives the resistance of a low enough temp the engine light should go off, unless it throws a code similar to "engine hasn't reached operating temp in x time". Also, if you have a 97+ (IIRC) your dash gauge won't work any more. You will also need a Wideband O2 sensor to see your AFR ratios.
