Re: 4.6L titan
Posted: July 7th, 2008, 8:23 pm
Which champion spark plugs do i need to run. I think im running a hotter plug from champion. could that cause a ticking noise underload?
Jeep - AMC 4.0L and 4.2L Stroker Enthusiasts
https://www.jeepstrokers.com/forum/
Spark plug heat range is often miss under stood, for the most part. and the new "Diamond fire" spark plug don't help the situation at allRedtj35 wrote:Which champion spark plugs do i need to run. I think I'm running a hotter plug from champion. could that cause a ticking noise underload?
Yes, I hope so also. I do remember a post about someone having major problems with a Titan stroker...bad cam, bad valve guides. You might want to check your rockers to see how much valve lash you have, and hopefully you haven't flattened a cam lobe.Redtj35 wrote:I have 24 lb injectors. And my jeep is distributor-less. Also i think im running the same plugs u r. Im going to go get some of the Champion RC9YC4 to see what happens.
I have adj, my map sensor from like 5-6.20volts and nothing changes it seems like. Stock voltage was 5.15volts in my TJ. I hoope its pinging im experiecing not a major problem!!!
If the cam was just starting to fail, Then NO....For the most part you are right, it would make noise at idle as well and running down the road. BUT you noise is only when its hot, and under a load.( you said 3 or 5 gear)Redtj35 wrote:But wouldnt I be hearing the noise all the time if it was something serious??
Sorry for the n00b question but I have a titan 4.7 in my TJ and just came across this forumdwg86 wrote:Yes, I hope so also. I do remember a post about someone having major problems with a Titan stroker...bad cam, bad valve guides. You might want to check your rockers to see how much valve lash you have, and hopefully you haven't flattened a cam lobe.Redtj35 wrote:I have 24 lb injectors. And my jeep is distributor-less. Also i think im running the same plugs u r. Im going to go get some of the Champion RC9YC4 to see what happens.
They are Hyd, no adj necessary..............If it sounds like it need a valve adj........it probably need a new cam and lifters.AlexTJ wrote:Sorry for the n00b question but I have a titan 4.7 in my TJ and just came across this forumdwg86 wrote:Yes, I hope so also. I do remember a post about someone having major problems with a Titan stroker...bad cam, bad valve guides. You might want to check your rockers to see how much valve lash you have, and hopefully you haven't flattened a cam lobe.Redtj35 wrote:I have 24 lb injectors. And my jeep is distributor-less. Also i think im running the same plugs u r. Im going to go get some of the Champion RC9YC4 to see what happens.
I have adj, my map sensor from like 5-6.20volts and nothing changes it seems like. Stock voltage was 5.15volts in my TJ. I hoope its pinging im experiecing not a major problem!!!(usually on JF)
I was wondering how to check the valve lash, as I will be indexing my distributor and will have the valve cover off anyway
Thanks, but how I can I check the valve lash to see if those things are good?Flash wrote:They are Hyd, no adj necessary..............If it sounds like it need a valve adj........it probably need a new cam and lifters.AlexTJ wrote:Sorry for the n00b question but I have a titan 4.7 in my TJ and just came across this forumdwg86 wrote:Yes, I hope so also. I do remember a post about someone having major problems with a Titan stroker...bad cam, bad valve guides. You might want to check your rockers to see how much valve lash you have, and hopefully you haven't flattened a cam lobe.Redtj35 wrote:I have 24 lb injectors. And my jeep is distributor-less. Also i think im running the same plugs u r. Im going to go get some of the Champion RC9YC4 to see what happens.
Welcome by the way![]()
Flash
lol cool. I assume the same would be true if it were NOT running?Flash wrote:the valve lash is held at 0 by the Hyd lifter when the eng is running.
If all the push rod have 0 play Your good!
Flash
