Kendall GT-1 back?
- seanyb505
- Stroker Displacement: 280ci
Kendall GT-1 back?
I saw it on the shelves at advance auto today, is it back? Does anyone know if its the same formula? I looked on the back and it said it was based in Houston, Texas. I thought the original gt1 came from Pennsylvania? Thoughts?
It was 20w50 btw
It was 20w50 btw
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
- Plechtan
- Vehicle Model: Comanche
- Alex22
Re: Kendall GT-1 back?
If you are looking for the origional kendal oil then buy the Brad Penn oil.
From what I heard, Kendal started using cheaper oil in their product so the residents of Bradley Pennsylvenia started selling their oil themselves.
Not sure whats in the "new" kendal oil.
- seanyb505
I just hadnt ever noticed it, didnt know if there was an actual chemical relationship to what the brad penn stuff is.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
[quote="Alex22"]If you are looking for the origional kendal oil then buy the Brad Penn oil.
Not sure whats in the "new" kendal oil.[/quote]
Not a true statement.
If you follow the link you will find that the 20w-50 is the only GT-1 product that has ZDDP levels of the past. The other "flavors" of GT-1 do not have the same chemical make up.
20w-50 is the same as Brad Penn.
- 1bolt
I don't know why anyone would put 20w50 into an engine that isn't suffering from either shot bearings or worn out rings.
What kind of Oil pressure are you guys seeing running that stuff?
I had a friend once who used 20w50 castrol in his leaky power steering pump res, anything else leaked out in an hour, but 20w50 would get us around town for a whole day
Irrational or not, I have visions of oil that heavy coming out of the cam squirter on the rod end like pancake syrup from a bottle of log cabin![Slobber :slobber:](./images/smilies/slob.gif)
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
Simon
Simon
- Alex22
Here is the story on Brad Penn oil.
http://www.bradpennracing.com/history.html
My brother ran 20w50 in his truck until he finished the new engine, it was a 76 dodge 318 with unknown mileage, the needle would barley move at an idle with 10w30. He had almost 30psi at idle with the thick stuff.
Mine runs 70psi cold, 30-40psi warm idle, and 60-75psi throughout the revs with the hv melling and brad penn 10w30 racing on a 7.6K rebuild. I have been tempted to run a lighter-weight synthetic oil, such as a 5w20, and see how it runs and monitor the oil pressure. So far the Brad Penn has been good.
- seanyb505
Ive had almost exact opposite results with the bp 10w30. Idles around 50 cold, 10 warmed, and 25ish at cruise. If the engine gets worked or gets hot the oil pressure completely drops. Im debating running the bp 20w50 and rotella 15w40 with the zddp additive, which is why the kendall on the shelf caught my attention.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
- Alex22
What are your oil clearances on the rods and mains? and did you use the camsavers by any chance, they lower it a few psi. I'm running brad penn 10w30 in my stock 4.0 with 168k and have 30-40 at an idle and 60 above 1200rpm.seanyb505 wrote:Ive had almost exact opposite results with the bp 10w30. Idles around 50 cold, 10 warmed, and 25ish at cruise. If the engine gets worked or gets hot the oil pressure completely drops. Im debating running the bp 20w50 and rotella 15w40 with the zddp additive, which is why the kendall on the shelf caught my attention.
- seanyb505
Im not sure about my oil clearances, the machine shop checked them so they should be within tolerance(For a normal engine, not nessecarily an AMC I6). Cam saver lifters, yes. Going with Rotella 15w40 tomorrow.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
- Alex22
You were most likely at the high end of spec for clearances, which is good for a street engine, go for the thick stuff.
~Alex
~Alex
- seanyb505
I put the Rotella 15w40 in along with a bottle of zddplus. Dont know if thats worth it, but i figured i would try. Oil pressure problem solved, but now Im hearing noise at idle, which may alos be present at cruise only other noises are too loud to hear it. Its a slight knocking sound, I havnet been able to inspect anything yet. Engine only has 4000 miles on it, so Im worried.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
