5.0L Clegg Stroker in my future... anyone else have one?
Re: 5.0L Clegg Stroker in my future... anyone else have one?
The longer stroke of the 4.6 makes it produce more torque, especially at lower rpm, but it also limits piston speed and probably won't tolerate as much boost as a 4.0.
- D'sJeepWrld
- Stroker Displacement: 4.0
- Vehicle Year: 2005
- Vehicle Model: LJ
gotcha man thank your for the info !Cheromaniac wrote: ↑March 5th, 2024, 10:43 pm The longer stroke of the 4.6 makes it produce more torque, especially at lower rpm, but it also limits piston speed and probably won't tolerate as much boost as a 4.0.
I had similar thoughts. I'm considering 30-pound injectors.Cheromaniac wrote: ↑December 1st, 2022, 10:33 pm That looks like a pretty decent kit since it includes an Eagle 4.06" stroke crank, Scat forged rods, and custom forged pistons with a 9.5:1 CR.
The supplied 24lb injectors are probably too small given that this stroker has 300+hp potential.
https://www.cleggengine.com/jeep-stroke ... l-9-3-1c-r.html.html
- Vehicle Year: 2004
What RPM is a 4.06" stroke limited to?Cheromaniac wrote: ↑March 5th, 2024, 10:43 pm The longer stroke of the 4.6 makes it produce more torque, especially at lower rpm, but it also limits piston speed and probably won't tolerate as much boost as a 4.0.
Since the bottom end is forged, I'd suggest no higher than 5900rpm.Brianj5600 wrote: ↑May 26th, 2024, 12:33 pmWhat RPM is a 4.06" stroke limited to?Cheromaniac wrote: ↑March 5th, 2024, 10:43 pm The longer stroke of the 4.6 makes it produce more torque, especially at lower rpm, but it also limits piston speed and probably won't tolerate as much boost as a 4.0.
