denso 12582704 injectors
- Vehicle Model: xj
as anyone ever used these injectors and was it a plug and play? did you like them?
Re: denso 12582704 injectors
They're rated to flow 25.1lb/hr at 43.5psi and being an Uscar EV6 type, they'll be plug n' play on '96+ Jeeps.
Since '96-'04 operate at a fuel pressure of 49psi, those injectors would flow 26.6lb/hr which is enough to fuel a stroker making close to 270 crank HP.
The '05-'06 TJ operates at a fuel pressure of 58psi, and the same injectors used here would flow 29.0lb/hr which is enough to power a stroker making close to 300 crank HP.
- Vehicle Model: xj
thank you. this is going into a very strong 4.6 stroker. from what you have tolled me this is just what I need.
thank you very much
thank you very much
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
