My "stroker" plans
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
Re: My "stroker" plans
Post by W_A_Watson_II »
Parts have been arriving. I now have the following:
New (made in china) Exhaust Header
Performance Valve Springs & Retainers
K&N Pro Series Oil Filters
COMP Cams SK68-232-4 - Xtreme 4x4 Cam and Lifter Kit
COMP Cams 104 - COMP Cams Engine Assembly Lube
COMP Cams 159 - COMP Cams Engine Break-In Oil Additive
E3 Spark Plugs E3-58
Rugged Ridge Jeep Air Intake System Part #17750.04
Rugged Ridge Jeep Cover
Still waiting on the Engine Block, Head and Tranny Shops to complete their parts.
You'll be like a kid at Christmas now. ;)
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
More parts have arrived AND Donnelly Machine, called and the rod are in the pistons, so I went and picked up everything, and paid the bill. Everything looks good, no machining to the rods small end to fit the pistons, so that was good. Now to start the engine re-assembly!
The Hesco 4.0L Performance Valve Springs & Retainers #HESSPRSS6 installed:
1.750" Installed Height & 105/110 #'s Seat Pressure at rest.
In addition to picking up the Engine Block, Head and Pistons from the machine shop I got the frame painted with the Chassis Black (still a little wet in these pictures). I'll still need to pull the wheels and paint the outer portions of the axles, but I can start re-assembling the drive train, that is as soon as it's all together. Now to start the Engine Assembly.
Will
http://jeep.wawii.com
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
Well, today I was going through the parts inventory and browsing the manual making sure I was ready to start the re-build. While checking parts, I discovered I had the wrong pistons. :doh: I ended up with my first recipe attempt pistons that required the 4.2L rods and piston dish machining rather than the final selection that used the 4.0L rods and had a larger factory dish. So I'll return these pistons and rings and have the rods removed and installed on the correct pistons that the shop already has on order. Donnelly Machine has been great and I don't fault them they are helping a lot. I also received the new Venom fuel injectors and the Air/fuel Ratio Gauge as well as the push rod length gauge needed to select and then order new push rods. You can also see my old dirty problematic IAC valve and the new one in the first picture.
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
After reviewing the shops information and my final parts selection, here is wher eI think I am:
Resulting Engine build Specifications:
□ - 3.905" - Bore (30 over)
□ - 9.450" - Deck Height (not milled, measured by machine shop)
□ - 3.895" - Stroke, Jeep 4.2L 3.895" crank
□ - 6.125" - Connecting Rod, Jeep 4.0L
□ - 1.353" - Pin Height (Keith-Black Silvolite (UEM) forged stroker IC944 Pistons, 21cc dish volume)
□ - 0.041" - Compressed Head Gasket Thickness
□ - 0.0245" - Deck Clarence
□ - 0.0655" - Quench Height
□ - 57cc - Head Combustion Chamber (Head milled 0.006", need to measure to veify)
□ - 280 cu.in. / 4.6L
□ - 9.38 Static Compression Ration (SCR)
□ - 8.05 Dynamic Compression Ration (DCR)
□ - 89, Likely required Octane
□ - 240/315 Likely HP/TQ Ratings?
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
Well, the shop called, and they can't get the IC944 Pistons for 4+ weeks. SO I've had to order them else where (slightly more expensive) and will take them in to the shop when they arrive.
http://www.jeepforum.com/forum/f12/star ... st14094522
http://jeep.wawii.com/93YJ_TrannyJob.htm
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
Well, discovered I had the wrong main bearings as well (for up to 1990). So when the Icon pistons arrived from Summit today I took them and the incorrect main bearings to the shop and hope to have everything by Friday. Also the standard rear main seal in the gasket kit didn't have the needed ears, so I've ordered a correct one of those as well.
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
The New pistons arrived Wednesday, and today (Friday) I picked them up from the machine shop after they removed the wrong pistons, and machined the small ends of my rods to provide clearance to the bottom of the piston face (due to the short pin height pistons). I also picked up the correct main bearings and a few more items like a new Alternator while I was out. Seems my old one, in addition to being salt corroded, had a cracked housing, figured change it now rather than later. Now to start the Engine Assembly, that is now that I hopefully have everything I need.
Will
I'm confused. Which pistons did they bore the block for?
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
The block was bored 30 over, however they ordered the Keith-Black Silvolite UEM-2229 +0.030" bore pistons rather than the Keith-Black Silvolite (UEM) forged stroker IC944 Pistons, 21cc dish volume +0.030" that I had settled on.
The UEM-2229's require the shorter non-4.0L rods, the IC944's are a shorter pin height and use the stock 4.0L rods, and are dished 21cc rather than the 13cc.
Will
Those two pistons require a different clearance. You really can't just swap pistons like that with out checking and/or honing.
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
I didn't chnage, they ordered the wrong pistons. what's the clearance requirements for the on the UEM-2229? I believe the clearance for the IC944's is .0040" - .0050". Guess I better make sure I check with the machine shop that they used the correct clearances.
Will
For a NA street engine the IC944 should be around .003". DOn't know the clearance for the cast pistons, but the piston sizes vary too.
Clearance NEEDS to be checked.
W_A_Watson_II
Vehicle Year: 1993
Vehicle Model: YJ
Will do, already sent the shop an e-mail so when I call Monday they should have the answer. Just did a quick measurement, as best as my calipers measure, and my bore seems to be 3.894"-3.898".
I got the clerances from here: http://www.kb-silvolite.com/icon/clearance_pop.php
Calipers aren't accurate enough. You need a dialbore gauge and a mic. Use the mics to pull the measurement off the piston, set the dial bore gauge off the mics then compare to the cylinder.
Those clearances are for the 2618 alloy pistons, not the 4032 alloy used on the IC944s. There is a PDF with the correct sheet on here someplace. Here: http://www.kb-silvolite.com/assets/fhr_installation.pdf
