Stoke engine 4.0L turbo GT40
ca2a18
Stroker Displacement: 4.0L
Vehicle Make: Wrangler
Vehicle Model: sahara
Post by ca2a18 »
Hi,
All of this going in a Jeep Wrangler 97 that I 'm building for the street and strip. With 4 wheeling.
Parts list:
TURBO Garrett GT40
Tial wastegate 44mm
Tial BOV 50mm
Injector
Fuel system
B&M Shifter
Image"http://www.qzal.net"
http://www.jeepstrokers.com/forum/posti ... e=post&f=8#
:wiggle:
ca2a18
Re: Stoke engine 4.0L turbo GT40 with Dyno result
Post by ca2a18 »
Dyno result soon
Yeah. . . that's um. . . pretty cool
doublins
Post by doublins »
No intercooler? How much boost are you planning on running?
p.s. props to you- I absolutely love turbochargers, have owned several vehicles that I installed aftermarket turbos on, and there is just no equal.
That being said, if you´re going to run any legitimate amount of boost, I fear you will have problems with your IATs without an intercooler, unless it is cold where you live. It would never work in summer in Maryland, though.
ca2a18
Re: Stock engine 4.0L turbo GT40
Post by ca2a18 »
Thanks a lot Doublins for your comment >>>>>>>>>>
Unfortunately I don't buy intercooler until now and I will buy one soon, I running on dyno 332WHP and 385TQ with only 8 PSI of boost. :rockout:
Now summer is begin and my ghost :hrhr: sleep until the summer is finished because the weather is too much hot :oops:
My plan to make stroker at less 4.8L and increase more boost around 20 PSI
CobraMarty
Post by CobraMarty »
If you use a bored throttle body and 99+ intake manifold you would see more HP/TQ at same boost.
99 XJ M62 S/C
604rail_king
Vehicle Year: 1995
Post by 604rail_king »
An intercooler is still a good part to have, but you could lower your air temps with using an water/meth kit in the mean time. I'd suggest running 100% water for now until you boost higher and need the added fuel (meth).
ca2a18
Post by ca2a18 »
atias
Post by atias »
604rail_king wrote:An intercooler is still a good part to have, but you could lower your air temps with using an water/meth kit in the mean time. I'd suggest running 100% water for now until you boost higher and need the added fuel (meth).
i think you should definitely have this(water&methanol)
i'm running 50/50 mix, its gives you an intercooler effect,raises the octan level to about 110-116 (according to what the snow performance and aem says), eliminating detonation, and your get a much bigger tuning window without damagin the engine
:cheers:
ca2a18
Post by ca2a18 »
CobraMarty wrote:If you use a bored throttle body and 99+ intake manifold you would see more HP/TQ at same boost.
Thanks a lot CobraMarty >>>>>>>>>>>>
I know that when bored throttle body and 99+ intake manifold you would see more HP and TQ but I fear for engine damage, :brickwall: because I don't have intercooler
ca2a18
Post by ca2a18 »
Thanks a lot 604rail_king for your devise >>>>>>>>>>>
I bought AEM water injection kit and I will Install it & see the result.
ca2a18
Post by ca2a18 »
:cheers:
I will try to put VP fuel race Q16 and meth
atias
Post by atias »
you need the C-16 is for high intake temps not the Q-16 ,i think the Q16 is highly oxygenated to gain more power. not good for you
:cheers:
ca2a18
Post by ca2a18 »
atias wrote:you need the C-16 is for high intake temps not the Q-16 ,i think the Q16 is highly oxygenated to gain more power. not good for you
:cheers:
Unfortunately I bought Q16 for it , and I will see what performance I will get.
CobraMarty
Yes it will be more power but with less boost and with less boost-less heat with no intercooler. Safer.
99 XJ M62 S/C
Users browsing this forum: Semrush [Bot] and 0 guests
