Valvoline VR1 oil
Valvoline VR1 oil
http://www.valvoline.com/products/VR-1% ... %20Oil.pdf
Check out the specs on the valvoline VR1 oil zinc .14 / phosphorus .13 This should be good for our flat tappet cams. I just bought a case of 10w30. I couldn't get it at autozone or advance. I got it from a mom and pop auto parts store. They ordered me a case yesterday, I picked it up today. $4.59/quart. If I could acually talk to someone witha brain at autismzone maybe they could order a case. They sell 20w50 on the shelf for $3.89/quart.
I acually made the mistake of asking someone at autismzone if they could order me a case. He acually punched in his computer the year, make, model and engine size of my Jeep and then said they don't make it for your car...MORON!!!!!!!!!!!! I had to leave before I hit him.
Re: Valvoline VR1 oil
Been there done that. I always look it up on line. and come in with a list of part numbers.dwg86 wrote: I acually made the mistake of asking someone at autismzone if they could order me a case. He acually punched in his computer the year, make, model and engine size of my Jeep and then said they don't make it for your car...MORON!!!!!!!!!!!! I had to leave before I hit him.
I've found Advance Auto Parts to be be the least moron filled parts slingers chain.
VR-1 is a good oil. And like your research shows it has a lot of "good stuff" in it.
But I would ask that you do some research on "racing oils" and there properties. Typical RO (like VR-1) is missing a number of additives for an extend drain interval. One of which is the detergent levels.
Before this thread goes goofy like some recent ones. Do yourself a favor and learn more about your product.
I AM NOT saying not to use it. Just understand HOW to use it.
It's my understanding that the VR1 has the needed detergents. The Valvoline conventional racing oil in the black bottle DOES NOT (As per phone conversation with Valvoline tech). The valvoline tech said the VR1 is good for my flat tappet engine and good for 3000 mile drain intervals
On the product information PDF, the VR1 states that " Valvoline VR-1 Racing Motor Oil is for use in any car, light truck, van, or SUV where API “SM” is recommended". The black bottle racing oil info... "Note: The Valvoline NOT STREET LEGAL RACING MOTOR OILS are recommended for racetrack applications only."
I'm not going to get into a long debate about "what engine oil is best for flat tappet engines". I have read WAY too many on the internet. I am NOT an oil expert or claim to be. I'm just sharing some info on my research. Take it for what its worth, do some research, make some calls, and decide what you are going to run in your vehicle. I'm going to run VR1. Nuff said.
Good deal, I lumped VR-1 in with the typical RO`s.
Sounds like you may have hit a good product !! :cheers:
- RAPTORFAN85
I was just on the phone with comp cams and he actualy recomened VR1 by name.
This is what I will be running in my stroker.
"Strrrrroke me, stoke me...."
Billy Squire
Billy Squire
The 10w30 is hard to find. Napa can get some for 4.99 a quart. I got a case from a local no name part store for 4.59/quart.
My local Napa had the VR1 in 10w30 on the shelf... The bottles look like they don't sell very much of it. After I dumped the Joe Gibbs cam break in oil I used the VR1... still sorting out problems with the engine though.
I was talking with my machinist yesterday. He runs a drag car, and he uses VR1 20w50(good for drag car but use 10w30 for street). He tells all his customers to use Brad Penn or Joe Gibbs Breakin oil and then use VR1 oil for all flat tappet cams. He hasn't had cam any issues yet.
If your concerned about detergent levels please have a VOA performed before jumping to conclusions, or believing the hearsay. VR1 has plenty of detergents to run in reasonable OCI. Its all about break-in, after that the massive doses of ZDDP are not necessary. There are many papers on this very subject, check out SAE for instance. FWIW SM oils are backwards compliant, and there are two, not one, but two flat tappet tests for SM oils. Not saying to use them for break-in, this is where most problems arise. You DO need the extra AW adds for break-in. Not trying to insult or start arguments, just simply saying consider the sources.
BTW all oils listed above are excellent oils.
If interested there is a recent VOA of VR-1 10w30 on BITOG...I wouldn't think twice about running it for 5k mi!
cavaliers1323 wrote:If interested there is a recent VOA of VR-1 10w30 on BITOG...I wouldn't think twice about running it for 5k mi!
Do you have a copy or link to the info?
I'm on my phone right now, I'll post up a link once I get home. But if you go to bobistheoilguy.com and click on "oil forums" then scrol down and click on "Virgin Oil Analysis" under "Oil Analysis" you will be able to see it. Everything is titled by it's brand and viscosity so the title of this one is "Valvoline VR-1 10w30"
