New 4.6L stroker build
Posted: October 25th, 2008, 8:43 am
This will be going in my daily driver 2000 XJ. It will be based around the KB 944 pistons in .030 over with the 21.73cc dish. I am going for reliability. I am shooting to use regular octane gas. I thought about going the Eagle/Ross route, but that was just too expensive. The machine work will be done by Baldwin Performance in Radford, Va. I will be picking up a used 4.0L block tomorrow hopefully. The crank will be purchased from Autozone without the bearings (they do let you know how much was taken off so you can purchase the appropriate bearing.. correct?). I am leaning toward using the compcam 68-231-4 with their nitriding process. I will also be using a MLS .051” head gasket as the .043” may be hard to find in the future and as of now I can only get them from CarQuest.
The rods I am thinking of either going with the refurbished ones from falcon or with a set of used rods. And pros or cons of either?
For the head I will be using the 0630 casting that I ported and polished a while ago. It has the Mopar Performance valve springs, retainers and keepers installed at 100#, 30* back cut valves, and a 3 angle valve job. Harland Sharp adjustable roller rockers. Intake is a matched 2000 with a 63mm throttle body. 26# Ford injectors. Doug Thorley header.
I am undecided on the lifters to use, probably either a set of CompCam’s (I think you can get them with an oiling hole in the bottom) or Crower Cam savers.
Part - Description - Part number - Supplier
Main bearings - Clevite 77 TM - Ms1947P - Falcon
Cam bearings - Clevite 77 - SH1980S - Falcon
Rod bearings - Clevite - CB960P x6 - Falcon
Oil pump - Melling - mel-M81A - Falcon
Freeze plugs - Pioneer - PE-256-BR - Falcon
Rod bolts - ARP - 112-6001 - Falcon
Pistons - KB - KB 944 - ?
Crank spacer - Hesco
Timing set - JP performance - JP5629
Crank - 12 counter weight - 3214723 - Autozone
Rods - 4.0L - BP773 - Falcon
Cam - Comp Cam - 68-231-4 - Comp cam
Lifters - ???
According to our calculator with a .01 deck clearance I will have a 9.27 SCR, a 6.96 DCR and a .061 quench. I have been thinking about going with a 0 deck clearance which would give me a 9.45 SCR, 7.09 DCR and a .051 quench. I can’t understand where Keith Black got their 9.1:1 compression ratio from though.
My cam choice and lifter choice are the only two variables that I am not terribly sure on. Any suggestions and comments are welcomed.
Lifters - ???
