Question about TB
Plechtan
Re: Question about TB
Post by Plechtan »
Nice piece, but most people here are not willing to shell out $450.00 for a throttle body. Dino ( Cheromaniac) included. Here was his solution to an oversize throttle body.
http://www.angelfire.com/my/fan/MustangTB.html
Peter Lechtanski
omegatron
Post by omegatron »
Totally...$450 for a TB is a little steep...that's what makes the 68mm dakota body so enticing ($60 ebay)...i think it might even be less expensive than my local machinist boring out a standard jeep tb. Plus, it looks like the factory sensors plug into the dakota tb as opposed to the splicing dino had to do.
Plechtan wrote:Nice piece, but most people here are not willing to shell out $450.00 for a throttle body. Dino ( Cheromaniac) included.
You got that right!
Anyway, I think a 62mm TB is more than adequate for a mild 4.6 stroker like mine. Anything bigger (like my modified Mustang Cobra 65mm TB) is overkill unless you're building a higher HP stroker. Otherwise you'll find the throttle very sensitive on tip in which makes rockcrawling or offroading on slow trails quite a challenge. I spend 99.99% of my time driving my Jeep on the street so it's not an issue for me and I love the whipcrack throttle response.
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
65mm it is then i suppose.
commandtoad
Post by commandtoad »
after fighting the touchyness of the 70mm, i finally broke down and swaped out to the factory TB. in comparision it is very lazy, and very controlable at crawling speeds. it cold starts better and to be honest, at WOT, i can't tell a difference in power, except maby right before the rev limiter. if anything i gained a small amount of bottom end off idle. maby, if i could fine tune the computer, i'd work with the 70mm, but for now, i'm keeping the stock TB.
Biggrnjeep97
Post by Biggrnjeep97 »
lafrad wrote:is the IAC with this motor plug and play with the Jeep TB?
How bout the TPS? I'd be sweet if we could all go the junkyard and get a 4.7 V8 throttlebody!
-Will
Dmondeac
Post by Dmondeac »
I have been looking at the throttle cable connections and this TB(Dakota) opens the opposite way, how are you guys getting around this?
BADASYJ
Post by BADASYJ »
Looks good man. I want to do the same thing with mine. What motor and year dakota TB are you using?
commandtoad
i had the same problem on the ford unit i used. i ground the plate off the shaft, took off the butterfly, turned the shaft around and re-assemble, tack the plate back on the shaft.
this is it when i finished.
clicking on the pic makes it just big enough to see.
Dmondeac
Post by Dmondeac »
love the CAT yellow paint!
commandtoad
easy to paint. you don't have to worry about overspray. 8-)
pma4x4
Where's the "any" key?
Post by pma4x4 »
I ended up going with the fastmans Jeep 62MM TB on my build. This was in conjunction with a 99+ upgrade and adding a Gibson Snorkel for cooler and more airflow.
http://www.arbrtek.net/xtek/fastmans.html
http://www.arbrtek.net/xtek/airfueltek.html
Uhm... Working on it
www.arbrtek.net
www.arizonaxj.com
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
